Attached Link: http://www.renderosity.com/viewed.ez?galleryid=145501&Start=1&Artist=Barbarellany&ByArtist=Yes
I use my cloak of invisability which is a black square texture map used in transparancy, then play with the max and min.if you want a real glass look, you could try to change the renderer. If you have an pc, get PoseRay here from the freestuff and the POVRay 3.5 beta from www.Povray.org and make real glass with reflection and refraction. All for free. Just give it a try...
A ship in port is safe;
but that is not what ships are built for.
-"Amazing
Grace" Hopper
Avatar image of me done by Chidori.
Rob, The mountains would get misty with distance, but the foreground and the mountains are of equal saturation and sharpness. Also, the woman would be reflected in the glass, even if dimly. Render her from the other side (pick the appropriate angle), flip it and slap it on your glass with a heavy dose of transparency. If she is sitting that close, her shadow would be sharper as well... adjust the shadow map for that light. Carolly
Basically all you need to do is make a black square (0,0,0) in a paint program like photo shop and save it as a .jpeg Drop it into the textures file where you can find it easily. I named mine *cloakof invisability, so It's on top. Then when you want to use it , load it in transparancy then set the max and min to 95 and 85 repectively to start. I play with the levels till I get it to where I want it. Add a color to tint the glass if you wish and add a bump map if you want for more interest as I did with the girl in the vase.
Attached Link: http://www.3dcommune.com/3d/galview.mv?Bryce+WsPHHOebg+1022793484
I just export and use Bryce.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Hi all does anyone have any tips on making realistic looking glass for windows in poser? I'm having a look in the tutorials as well just in case. Thanks in advance Rob
