Thu, Jan 9, 8:32 AM CST
Subject: realistic glass
c1rcle ( ) posted Thu, 06 June 2002 at 9:34 AM · edited Wed, 08 January 2025 at 6:57 PM
Hi all does anyone have any tips on making realistic looking glass for windows in poser? I'm having a look in the tutorials as well just in case. Thanks in advance Rob
tasmanet ( ) posted Thu, 06 June 2002 at 10:48 AM
Just fiddle around with the transperency dials
You could also add a Reflection Map
tasmanet ( ) posted Thu, 06 June 2002 at 10:55 AM
Set between 20 - 30% Tick multiply through lights
c1rcle ( ) posted Thu, 06 June 2002 at 11:33 AM
thanks I'll give it a go
Barbarellany ( ) posted Thu, 06 June 2002 at 11:36 AM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=145501&Start=1&Artist=Barbarellany&ByArtist=Yes
I use my cloak of invisability which is a black square texture map used in transparancy, then play with the max and min.
Barbarellany ( ) posted Thu, 06 June 2002 at 11:39 AM
c1rcle ( ) posted Thu, 06 June 2002 at 11:51 AM
very nice Barbarellany especially the girl in the vase
bantha ( ) posted Thu, 06 June 2002 at 3:41 PM
if you want a real glass look, you could try to change the renderer. If you have an pc, get PoseRay here from the freestuff and the POVRay 3.5 beta from www.Povray.org and make real glass with reflection and refraction. All for free. Just give it a try...
-"Amazing Grace" Hopper
cinnamon ( ) posted Thu, 06 June 2002 at 3:45 PM
Barbarellany do you have a tutorial available for that?
c1rcle ( ) posted Thu, 06 June 2002 at 3:50 PM
I'll have a look thanks bantha, here's what I was trying to do tho, it ended up not looking like glass more like a forcefield, thanks for the tips guys & girls. Rob
hauksdottir ( ) posted Thu, 06 June 2002 at 4:57 PM
Rob, The mountains would get misty with distance, but the foreground and the mountains are of equal saturation and sharpness. Also, the woman would be reflected in the glass, even if dimly. Render her from the other side (pick the appropriate angle), flip it and slap it on your glass with a heavy dose of transparency. If she is sitting that close, her shadow would be sharper as well... adjust the shadow map for that light. Carolly
Barbarellany ( ) posted Thu, 06 June 2002 at 7:43 PM
Basically all you need to do is make a black square (0,0,0) in a paint program like photo shop and save it as a .jpeg Drop it into the textures file where you can find it easily. I named mine *cloakof invisability, so It's on top. Then when you want to use it , load it in transparancy then set the max and min to 95 and 85 repectively to start. I play with the levels till I get it to where I want it. Add a color to tint the glass if you wish and add a bump map if you want for more interest as I did with the girl in the vase.
EricofSD ( ) posted Thu, 06 June 2002 at 8:33 PM
Attached Link: http://www.3dcommune.com/3d/galview.mv?Bryce+WsPHHOebg+1022793484
I just export and use Bryce.
c1rcle ( ) posted Fri, 07 June 2002 at 3:17 AM
I can see I've got a lot more to do to this picture then :) I shall get onto it right now, thanks everyone. Rob
