Forum Moderators: Staff
Bikermouse, It seems that the default Dawk geometry (blNudeMan_Gen.obj) has the genitals, and there is a subsidiary hip (blHipNoGen.obj) that is brought in when you un-tick the genitalia option in the figures menu, but I don't know enough about PZ2 editing to exploit this, and I don't understand why, if the genitals are part of the default geometry, they don't hide with actor genital:1 { off }
I read something about this - it's just the way they did it in poser 2. They didn't bother to change it in more recent versions for some reason. If you don't want to tell me ok - but the only reason I ask is I think I know what you were trying to do and was going to sugguest another way,but I'm not going to second guess you. - good rendering
What I am trying to do is hide all the body parts, except the arms and collars by the application of a pose file. Why do I want to DO it ? So that I will know HOW to do It. Why do I want to know HOW to do it. So that I can DO it. Why do I want to DO it? Sow that I will know HOW to do it. I am not trying to be obtuse, knowledge is an end in its self, it needs no justification, I could write several hundred pages on why I want to do it and still not have exhausted the subject, that would be wasting my time and yours, why I want to do it is irrelevant, the only important point is that I do, in the end the simple explanation is that I want to know.
You know I think there's a tutorial floating around here somewhere. that I think shows you how how to do this. Has to do with getting rid of nipples belly buttons and (heaven forbid), genitals. Might search the poser tuts section under "heros","turning off","bellybuttons", or something like that. Meantime - take a walk, enjoy the fresh air, unwind.
hmm ... this mention of "heros" "nipples" & "bellybuttons" sounds awful familiar ... i think you might be referring to my tutorial "poser custom modelmakers' guide", where i explain how to remove that stuff from a sample figure i named "myhero".
unfortunately it won't be of any help since it shows how to remove that stuff directly from the model's geometry using a 3rd-party modeller, not hide them from within poser. and the tutorial covers v3 and later, not 2. (tho i can't say it wouldn't work for v2).
the tutorial can be found at aarrgghh.com/poser.
I am tying to make a pose file to hide every body part except the arms and collars. I tested it on Posette and everything worked fine. I tested it on the Dawk and it worked EXCEPT for the genitals, which remain visible in spite of the lines; actor genital:1 { off } I have just spent the last 3 hours experimenting, and have run out of ideas. Does anyone know how to hide the P4 Nude Man's wedding tackle, from a pose file?
