Well, the T-Rex is about 14MB; DAZ's Michael and Victoria are each less than 4MB .... I can't really say. Some experimentation might be required to discover Poser's tolerance for high-res meshes, if that is the cause of the problem. It might also have something to do with the nature of the geometry itself. Are you using triangles, quads, or pentagonal polys? How many groups or materials? Every program has its limits. Unfortunately, I don't know the limits of Poser 3.
mickymouse it sounds like you've got a great computer system, and Windows 2000 Pro is a great operating system. If you can afford all that, why are you using Poser 3? It's an old program. Most likely you'll find that Poser 3 won't handle what you're doing, and that you're biting off more than you can chew.
Thanks ronknights. Well, yes you are right about Poser3, but here's the scoop. I actually model in Rhino 3D and render in Cinema 4D XL 7. I only got interested in Poser because some have expressed interest in my models, so I thought I would give it a try. I kind of hate to lay out the cash for Poser if this really doesn't work out and I never use the app. Basically I don't "Pose", I model. It would only be used to get the models into Poser format. There has been discussion with our teens that we might need to upgrade to get it to work correctly. Thanks
I imported in a OBJ file of a Lamp into Poser 3.01 and about 30 to 60 seconds after doing so... BOOM, my screen turns black and my computer is rebooting. This is the only time this happens, no other programs make this happen, nor does Poser under other normal use. I am running Win2K with 256MB RAM, NVidia GForce2 Graphics Card and a AMD 1.8Gig CPU. The OBJ file is 28MB. Any thoughts?
