Sat, Feb 8, 9:32 AM CST
Subject: plopp render question
thgeisel ( ) posted Sun, 23 June 2002 at 9:24 AM · edited Wed, 05 February 2025 at 12:36 AM
There was a thread some time ago that if you have made some little changes in a scene,that you can use the ploprender tool to rendern only that special part of the scene and add to the rest. How does that work,and im using b4
Aldaron ( ) posted Sun, 23 June 2002 at 10:04 AM
Once your changes are made then bring up the picture again, click-drag around the area you wish to re-render. A box should appear with 2 buttons and a triangle next to it, click the small button (not the ones way to the left of the screen or you'll re-render the whole picture) and just what is in the box will re-render. Once it's done select the small triangle and collapse selection then save image as you usually do.
thgeisel ( ) posted Sun, 23 June 2002 at 12:09 PM
Thanks alot!! Got it !!!!
