Fri, Jan 10, 12:32 AM CST
Subject: Large Render Problem
arrow1 ( ) posted Sun, 23 June 2002 at 3:01 AM · edited Thu, 09 January 2025 at 5:11 PM
I have spent the past three months working on a large project for myself.It includes 16 figures with hair,clothes and props on a 3d worlds terrain with cliff and sky.I thought I would render it at 200 dpi and 20cms wide (about A4 size)I Started rendering at 6.45 pm EAST Time and 7 hours later the render bar had not moved. Am I asking too much of Poser Pro Pack enhanced?My machine has 768megs of ram,a1330 Athlon chip and 100gig hard drive with 20 gigs free on the Poser drive.If Poser cannot handle this size render,How do other artists get to poster size,and Can anyone help or suggest a solution to making large renders? Cheers arrow1
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
scifiguy ( ) posted Sun, 23 June 2002 at 3:37 AM
You left out something important...what is your Operating system? If its Win98/Me you've very likely exceeded what its memory management can handle (actually, 768 is too much for Win98/Me to handle regardless of what you're doing). 16 figures is a lot, then add the scenary, textures, etc. and you've basically overwhelmed your OS. I installed XP and all render choking by Poser vanished. NT based systems are infinitely better at managing memory and I'm glad I upgraded if just for Poser's sake.
darkphoenix ( ) posted Sun, 23 June 2002 at 3:45 AM
For your current system, I would recommend rendering composites. If you have 16 figures, try rendering several scenes with different figures and then using a paint program to merge them together into one image.
arrow1 ( ) posted Sun, 23 June 2002 at 4:33 AM
Thanks for Your reply. I have windows 2000 Professional and I am looking at purchasing XP.
scifiguy ( ) posted Sun, 23 June 2002 at 6:37 PM
Since you already have Win2K changing to XP won't help you...you're already benefiting from NT's memory handling. Try defragging your drive (seems to help some folks) and check the size of your paging file. Even with that much RAM a very large complicated picture may need more swap space to get going. If you have manually set the paging, increase the size. If windows is managing it, it may not be able to resize it properly while Poser is trying to render. You can try manually setting it to a larger size. Also be sure you turn off anything running in the background so Poser can have all the memory and processor attention for itself. Another thought...Poser has a limit on the physical size it can render from the main window. I don't recall off hand what that size is or what happens if you exceed it, but you can render as a one frame animation to get past it. I hope you get it working :)
arrow1 ( ) posted Mon, 24 June 2002 at 3:34 AM
Thanks to all for your advice.I will look at technical side of things and keep you informed.arrow1
