Go to Sky Lab (Sky & Fog, click on the cloud) and there's a little button on the Sun & Moon tab, below Sun Controls, which has the caption Disable Sun Light. Uncheck it. As for the windows, make your wall positive. Remember, you have to squash the wall box in Z or X axis, so it's much thinner. My walls are X=200, Y=200 and Z=10. (they go below the floor and above the ceiling.) Declare it positive, create a small box with Z of 12 (X=40, Y=60 in my case). Position it so its center is on the center of the wall (you see the line), declare negative and then select both it and the wall, and group. you'll get a hole in the wall. The sill on the window is a squashed box, the window ... whatchamacallits are booleaned boxes done in the same way as the window hole. The glass is very thin boxes. You just have to pay a lot of attention to positioning.
-- erlik
Whether you build a room with a cube, or make separate walls, floor, ceiling is totally up to you and what you're aiming for. I've done it both ways. The traditional 3D way of doing rooms is to turn off sunlight and use lights only. But that doesn't mean you have to do it that way. I've done rooms that were lit only by the sun. They have a different look and that's fine too. Purists would disagree of course! LOL
It's the detail that counts. Look around the room you're in now, and observe all the places it deviates from four blocks for walls and two planes for floor and ceiling. Look for: wainscotting, door frames, window frames, window sills, cornices, recesses, flat arches. Most rooms are not straight boxes. Incidentally, I reckon rooms are one of Bryce's strong areas because of the useful tools it provides for rotating and positioning things in a precise way.
Good Morning all I've recently been bitten by the 3D bug so I've been playing with bryce, I need a good tutorial on how to make rooms. If any one out there knows plase tell me where can I find one.
Ask me a question, and I'll give you an answer.
