Fri, Nov 22, 10:40 AM CST
Subject: Creating a cave using a negative lattice
LoRd_FoO ( ) posted Sat, 13 July 2002 at 10:20 PM ยท edited Thu, 21 November 2024 at 1:56 PM
I'm trying to create a cave like structure using a normal mountain-like terrain and a lattice made negative. For some reason nothing will ever show up negative. I've tried several different models. Is there something that I'm doing wrong? I have a terrian, I create a lattice that intersects the side of the terrain, and in the attributes options, select it as a negative. Thus, it should cut a "hole" in the side of the terrain, shouldn't it? Please, any help would be greatly appreciated.
Aldaron ( ) posted Sat, 13 July 2002 at 10:32 PM
You need to group them together, then it will show up but only when rendered.
LoRd_FoO ( ) posted Sat, 13 July 2002 at 10:35 PM
i'm pretty sure i tried that.. but it didnt show up.. i will try it again... what kind, if anything at all, should i texture the lattice with ?
ringbearer ( ) posted Sat, 13 July 2002 at 11:54 PM
Make sure your terrain is set to solid. Should do the trick. Arleen
There are a lot of things worse than dying, being afraid all the time would be one.
EricofSD ( ) posted Sun, 14 July 2002 at 4:16 AM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=48308&Start=1&Artist=EricofSD&ByArtist=Yes
Its not so great, but this cave was done by putting one rock inside another and making the inside rock boolean then grouping.
Rochr ( ) posted Sun, 14 July 2002 at 7:18 AM
Not sure if youve tried this, but the lattice you want to "dig" in, must be set as positive.
Rudolf Herczog
Digital Artist
www.rochr.com
tuttle ( ) posted Sun, 14 July 2002 at 1:40 PM
Yeah, all of the above. Object 1 - positive, Object 2 - negative, group them together. Make sure they're not already part of any groups, or it won't work. If they are, ungroup and regroup after the boolean operation. The texture of the negative object dictates the pattern in the "hole", the texture of the positive object dictates the pattern of the outside, as normal.
LoRd_FoO ( ) posted Sun, 14 July 2002 at 11:00 PM
Attached Link: http://quim.dyndns.org/images/research/cave%20test.jpg
i tried creating a very basic cave model. this is the test render. It's not all that great. I'm going to clean it up. Just figured I would post it anyway.
