Wed, Nov 6, 9:35 AM CST
Bryce F.A.Q (Last Updated: 2024 Oct 30 3:44 am)
Subject: 3D text in bryce 4?
superjunk ( ) posted Sun, 14 July 2002 at 10:50 AM · edited Wed, 06 November 2024 at 9:33 AM
wat do i need 2 do 2 make 3D text in bryce? plz help....thanks
tjohn ( ) posted Sun, 14 July 2002 at 11:25 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=775421
Here is a link to a recent thread on the subject here at Bryce Forum.
kwmedia ( ) posted Sun, 14 July 2002 at 12:48 PM
black bkgrd, white lettering, saved as bmp... import into lattice feature, place the bmp in both areas and check ok, then from there, you do you manipulating, texturizing, etc.
EricofSD ( ) posted Sun, 14 July 2002 at 4:30 PM
I've used both the lattice and elefont, as in that thread above. Elefont gives crisp fonts that can be manipulated. The edges of the letters are rougher in lattice work.
EricofSD ( ) posted Sun, 14 July 2002 at 4:31 PM
airflamesred ( ) posted Mon, 15 July 2002 at 12:18 AM
change the record eric - i find it much neater to use a terrain @ 512 then clip top and bottom
FWTempest ( ) posted Mon, 15 July 2002 at 4:14 AM
can elefont create text effects, too? don't know much about it. For instance, I always used the lattice method, because if I needed to I could use Painter (and/or other programs) to create text on a curved baseline, rather than simply straight across. And the only time I've had a problem with rough edges is if I use some cute-sy font with lots of curly-ques. not trying to put down a program I know little about, just curious what it can do.
Phantast ( ) posted Tue, 16 July 2002 at 5:00 AM
The easiest way is to use a 3d modeller. Anim8or is free, and fine for tasks like this. Type in your text, save as .obj, import to Bryce and off you go.
Moonstone ( ) posted Tue, 16 July 2002 at 9:04 AM
where can we find the Anim8or? So we can experiment with the texts.
Aldaron ( ) posted Tue, 16 July 2002 at 10:02 AM
Attached Link: http://www.anim8or.com/
Anim8tor is also an animation program, it's renderer is still in it's infancy. And of course it's free.
igohigh ( ) posted Tue, 16 July 2002 at 12:19 PM
Attached Link: http://www.armanisoft.ch/webdesign/Elefont.htm
make your own 3D Text with any font on your system for Free! EleFont: http://www.armanisoft.ch/webdesign/Elefont.htm (only makes DFX) P.S. They have a Spiralizer too;p
