remember if you start having troubble .rsr file is the one to get rid of. poser looks for it to use but it also makes a new one. if .rsr file is larger than .crc file then the rsr most likely is bad. i often go to the objects folders and erase all .rsr there. also keep a good copy of the main poser.rsr , .crc , .exe files in a safety folder to coppy back to the main Poser folder if anything goes wrong so you won't have to reload poser
hi guys, somehow i detstroyed the uv maps of victorias bikini top and bottom :( i dont know how this could happen (though i downloaded and installed a lot) i replaced the obj files with the originals but this didnt help. (in poser it only shows with the mesh collor and in 3dmax it says that it has NO UVMAP!!!?!?) i dont want to reinstall poser and all stuff because my "runtime" folder has more than 1.5 gig and that would be sooo much work. does anyone have an idea how i can fix this? can i get (and reapply) the uv map somewhere (from daz or anyone here)? thanks for trying to help leyla
