Sun, Jan 12, 1:55 AM CST
Renderosity Forums / Fractals
Welcome to the Fractals Forum
Forum Moderators: Anim8dtoon, msansing
Fractals F.A.Q (Last Updated: 2024 Nov 13 3:03 pm)
Subject: Printing Fractals FYI
jockc ( ) posted Wed, 17 July 2002 at 10:01 AM · edited Sat, 11 January 2025 at 11:15 PM
I wanted to print in something other than 8x11 so I used printroom.com based on the recommendation on Janet Parke's website (http://www.parkenet.org/jp/print.html).. I am very happy with the results. I ordered two 20x30 prints, a mug and a t-shirt on Friday 7/12. Just got it yesterday 7/16 and they look great. I will be doing a lot of business there.
FractalGrrl ( ) posted Thu, 18 July 2002 at 3:51 AM
Can you tell me what resolution you used? I've been looking on their site, and other than an image size based in pixels, I cannot see if they want 600dpi, 1200 dpi or what. Any info would be appreciated. :) Tina
jockc ( ) posted Thu, 18 July 2002 at 11:45 AM
I never found any info on DPI either. What I found (probably what you found also) was the max total resolution they support is 17,000,000.. so max would be 5000 x 3333 for a 2/3 aspect or 4750 x 3562 for a 3/4 for example. That is what I sent for the 30x20 print. For a mug or t-shirt or one of the other items obviously a lower res would be fine. They scale the image to the proper size if it is large. I took the 20x30 prints to have them framed and I think they are going to look spectacular.
kchildress ( ) posted Thu, 18 July 2002 at 1:41 PM
I've had excellent results using EZPrints, www.ezprints.com. As far as DPI is concerned, I generally use 200 DPI and haven't had any problems. Some places will require higher DPI, but these are generally the more higher-end custom places. You should be able to get quality results using anything in the range of 150-300 DPI with the mass-market places like PrintRoom, EZPrints or Ofoto. Experiment to determine what is best for your needs.
FractalGrrl ( ) posted Thu, 18 July 2002 at 3:41 PM
Hey, thanks you two. :) I think I'm going to join over there. The prices seem very reasonable.
