Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 1:08 pm)
OK, let me explain. DAZ's textures traditionally don't need any sort of fiddling with BUMs and stuff. The textures are good to go right out of the box. That has always been a good hallmark of DAZ... Other people who supply textures often require you to go through that extra step. Never DAZ. There are no "...bum.jpg" files in the texture section. I've checked. If there were, this would be a step backward for DAZ. They've never handled their textures this way. When this bum file is not found, Poser locks up for a very long time. I haven't seen that happen very often since I started using Windows XP. I wasted a good hour or so fiddling with this problem. That's not a good thing. The texture I've bought is described as "medium," and "standard." I have no idea why the texture seems to have two names. I've checked my purchase history to verify the two names. As of tonight I've received no response from the DAZ tech email address. Frankly I'm surrprised at that. Maybe their customer service email address is more responsive. I'll try them now.
Ron, there is nothing wrong, you have to convert the StephBodyB.jpg and the StephHeadB.jpg file to a bum file in order to use the P4 Matpose files. There are no bumfiles supplied with the purchase - you have to do this yourself. I just installed the Stephtextures again into a seperate folder to see what's in there because I always delete all the P4 stuff as I use ProPack. The purchase only comes with jpg files.
Every
organisation rests upon a mountain of secrets ~ Julian
Assange
I got these textures awhile ago, and am finally trying to use them. I was surprised to see the P4 texture is missing the stephheadb.bum file. I've never run into this problem with DAZ stuff before. I'm letting you know in case you get this texture. I have sent an email to DAZ tech support about the problem. I won't get a reply till tonight probably since I am heading to work soon.
