I always use a textured square for my ground. If you can make the groundplane take a shadow, I've never learned the trick. The shadow you see in the object window is a guide tool to help you position things. 1)antialias: Yes if you want clearer, sharper shadows. Turn it off for faster renders. Also for a sharper shadow you need to set the shadow map for the light to at least the same long dimension of your render. 2)Cast shadows: You betcha.. both for the objects and for the lights.. 3)Background and lights? Suit yourself, be creative.
Many Thanks for your reply.What my trouble seems to be is I haven't yet been able to render one ground shadow of any sort.I have gone to the poser manual,it is not much help.I seem to be doing something wrong.Cheers arrow1
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses. Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
I think I might be getting the idea. I am about to go to bed now.Can I post an update tomorrow. Cheers arrow1
Actually I think The first dial named "shadow" is the darkness of the shadow. If you dont want a light to cast shadows it's best to uncheck in the lights properties. This way it renders faster since it doesn't have to render a shadow map. c1rcle, 3 lights. I think the 2 without shadows are around 70-80%. Just wanted to show how where your lights are at it effects your shadow. Obviously since light causing the strange shadow color is to the right it only hits flat areas of objects. If it had shadows on this wouldn't happen.
I am still having trouble trying to render ground shadows in Poser ProPack.I have been following a tutorial by Robin Wood.I have a few questions? Do you have antialias switched on,Do you have cast shadows switched on,Do you have Background colour,Black or background picture buttons switched on.In surface materials do I render entire figure or highlights.I know I am to switch everything to white. And finally do I have ground plane in the Object window. I have shadows visible on the ground in my screen. I have two figures with shadows under their feet. I have for past two weekends trying to get some ground shadows rendered to put into a picture I am working on. What on earth am I doing wrong? Hope Someone can help nelp me? Cheers arrow1.
