Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 22 2:19 pm)
Good new, bad new. This is a tricky problem and not an easy one. UV Mapper has the ability to select and drap individual points. You are unfortuanately going to have to unwrap your mesh and line it up by hand. Merrilyn Ellison (D'Mentia) remapped Posette to fit Vicki maps using UVMapper. So it is doable, but not easily. Anton Kisiel anton@daz3d.com
-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
UVMapper pro is a great upgrade from UVmapper but the process has to be don't by hand. For that the standard UV mapper does everything you need. SAve our uv's frequently since there are not any undo features.
-Anton, creator of
since 3-13-07
Well you can import a photo on to the map. there's a couple of tutorials on how to do that. (be careful with copyrights in that case. get a release from the person you photograph for the specific purpose you intend.) You can import the model into a modeling program. or you may want morph manager ? or morph 3d? http://www.innuendo.ev.ca/ - TJ
