Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 4:55 pm)
Sorry getting back to you guys took so long, Was busy yesterday. I would love to do a tutorial! As long as you understand that most of the work (modeling) was actually done in another program. The creation of an articulated prop is done in poser in the sense that the modeled pieces are brought in and put together, then added to the library. But, If that is indeed what you guys were talking about. I'll do it. :)
Yes it would be a figure or "articulated prop" Using the grouping tool you can set the texture for two seperate Objs in poser, then export them as a single object. Re-import them and they retain the texture group names. Or Group and texture name them them parent one to the other and create an articulated prop and both pieces will retain the texture names.
