Tue, Nov 26, 4:29 PM CST
Subject: first poser-bryce picture
Shiby561 ( ) posted Tue, 06 August 2002 at 7:02 PM ยท edited Tue, 26 November 2024 at 2:37 PM
How does it look? Please be honest, im new to this and want to know what i need to do better...
Shiby561 ( ) posted Tue, 06 August 2002 at 7:03 PM
I called it relaxing buety/beuty. however u freaking spell it... lol.
hendrikm ( ) posted Tue, 06 August 2002 at 7:13 PM
not bad... but if you make the figure as a silhouette (I cant spell THIS), the rocks need to be black, too...
sirkrite ( ) posted Tue, 06 August 2002 at 8:08 PM
You need to turn the Ambience down on the rocks. Right now it looks like she's sitting on glowing hot rocks.
Crescent ( ) posted Tue, 06 August 2002 at 10:43 PM
nu-be, that was my same, exact thought! ;-) My suggestions: Shorten her neck, it doesn't look right. (Standard Poser problem.) The pose isn't bad, but the hair needs tweaking: it isn't paying attention to gravity. You may want to rotate it downward. It won't look right on a normally lit model, but it will work for silhouette. I'd change the color of the rocks to a grey-blue. Not only would it look more realistic for lighting, but it would highlight the setting sun even more. You might want to zoom in a bit more, so that the female is larger. She'd create a nice framing effect with the sun in the middle. (Composition-wise, she's placed well, but I think the picture would add more impact if zoomed in more.) The sun/water is defintely done well. This is a good start.
Shiby561 ( ) posted Tue, 06 August 2002 at 11:34 PM
Hows this??? yes it is a recreation (a poor job of it cause the real one was FANTASTIC!) I did the figure in poser, bryce for the background and poorly done cloths in photoshop? how is it? I did a recreation cause im only toning my skills since I am new to this.
Shiby561 ( ) posted Tue, 06 August 2002 at 11:36 PM
Yes I know the lighting is all wrong hehe like the big rock in ur face. but i thought i had saved it in bryce but when i went back to mess with the lighting to make it better I found out i didnt save so i was stuck with it :(. maybe i should try fixing it with photoshop? yathink?
bikermouse ( ) posted Wed, 07 August 2002 at 3:55 AM
get rid of some of the haze or blend it closer to the sky color. the original post did look like the girl on 18 wheeler flaps. too bad you don't still have the pz3 or hadn't copied the pose. if you were to bend the legs at the knee a little you'll have it. Then when you model a semi trailer you'll be good to go for the figure on the flaps. - TJ
