Sharen I am weeping with you!
Poser 9 SR3 Â and 8 sr3
Processor Type:Â AMD Phenom II 830 Quad-Core
Hard Drive Size:Â 1TB
Processor - Clock Speed:Â 2.8 GHz
Operating System:Â Windows 7 Home Premium 64-bitÂ
Graphics Type:Â ATI Radeon HD 4200
•ATI Radeon HD 4200 integrated graphicsÂ
System Ram:Â 8GBÂ
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=816258
Hi Sharen, I asked the same question awhile back, and Kupa's answer was Poser 5 would use PNG's like the Pro Pack. Link to the original thread is attached... SpectreMy usual answer is to convert the png's to rsr with P3dO Explorer, but since it isn't working well for you ... ask someone really nicely to convert them for you? Or keep a bare-bones version of Poser 4.03 installed on your system, with most of the content removed, for the singular purpose of rsr creation. I'd happily volunteer for occasional conversion duty. It's the least I could do to help, after all you've contributed to the community.
Attached Link: http://www.departmentzero.com/downloads/RSRConv.zip
I normally do a 91 x 91 render of whatever I want to make into an RSR, and save it as a PIC file. I then delete the alpha channel in the PIC and use RSR Converter to turn the PIC file into an RSR. I then distribute the RSR and Pro Pack creates it's own PNG from it. Straight P4 uses the RSR. If P5 doesn't convert the RSR into a PNG like Pro Pack, you could also save the 91 x 91 render as a PNG and distribute it along with the converted RSR.... I have distributed both in the past, and since the file size of each is about 12k, it's normally no problem. RSR converter can be downloaded from the attached link. Hope that helps :) SpectreI can't thank you all enough for the help, I just don't want to leave the people high and dry, I think I will do it both ways, I just downloaded that file Spectre and hopes I can learn it, but if I can't I will be back for answers from you, thanks again so much for the help.....you are all such great pals....Sharen :-)
You're welcome, hope it'll be ok that time. Anyway it's a bit late, with the arrival of P5 the RSR pictures need is gonna die progressively. btw I should have told you before of the Rsr2Png update, sorry for the delay. When I saw your thread I realized I had forgot to do this. I'm a bit overwhelmed with projects those days, sorry again.
Yarp - author of P3DO Organizer for Poser
I am weeping cause I don't have it..... Kidding aside I do have a question, I see they have import png, will there be any rsr's anymore? Sharen
