Mon, Feb 10, 12:06 PM CST
Subject: Poser 5 - weep weep
SAMS3D ( ) posted Thu, 08 August 2002 at 12:02 PM · edited Mon, 10 February 2025 at 11:49 AM
I am weeping cause I don't have it..... Kidding aside I do have a question, I see they have import png, will there be any rsr's anymore? Sharen
pokeydots ( ) posted Thu, 08 August 2002 at 12:32 PM
Sharen I am weeping with you!
Poser 9 SR3  and 8 sr3
Processor Type:  AMD Phenom II 830 Quad-Core
Hard Drive Size:  1TB
Processor - Clock Speed:  2.8 GHz
Operating System:  Windows 7 Home Premium 64-bit
Graphics Type:  ATI Radeon HD 4200
System Ram:  8GB
Patricia ( ) posted Thu, 08 August 2002 at 12:36 PM
As a Mac person, I am weeping more--or at least for much longer!--than both of you put together.....I want that HAIR....(sob) (sniffle)
SAMS3D ( ) posted Thu, 08 August 2002 at 12:40 PM
LOL, you are correct Patricia, I feel for you, but let's get down to the question, png's and rsr's or just png's ????
wdupre ( ) posted Thu, 08 August 2002 at 12:56 PM
jeez, supporting both would be helpful, I'd hate to generate png's for my whole library, but I guess that would be a small price to pay for a new library system.
SAMS3D ( ) posted Thu, 08 August 2002 at 1:05 PM
I assume if you upgraded it would generate them for you right, take the rsr and make them into png, but my problem is converting them back again to rsr's, P3Dexplorer doesn't quite work well for me...Sharen
spectre3 ( ) posted Thu, 08 August 2002 at 2:28 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=816258
Hi Sharen, I asked the same question awhile back, and Kupa's answer was Poser 5 would use PNG's like the Pro Pack. Link to the original thread is attached... Spectre
SAMS3D ( ) posted Thu, 08 August 2002 at 3:08 PM
Thanks for your help.....Sharen
SAMS3D ( ) posted Thu, 08 August 2002 at 3:10 PM
Okay now that I know that, what happens to those people who don't use png, I use both png in pro and rsr in Poser 4, but what of those who don't have both and they can't use rsr's?
SAMS3D ( ) posted Thu, 08 August 2002 at 3:11 PM
I guess what I am really asking is, how do you apply the png's to work in Poser 4?
Little_Dragon ( ) posted Thu, 08 August 2002 at 4:42 PM
My usual answer is to convert the png's to rsr with P3dO Explorer, but since it isn't working well for you ... ask someone really nicely to convert them for you? Or keep a bare-bones version of Poser 4.03 installed on your system, with most of the content removed, for the singular purpose of rsr creation. I'd happily volunteer for occasional conversion duty. It's the least I could do to help, after all you've contributed to the community.
spectre3 ( ) posted Thu, 08 August 2002 at 5:09 PM
Attached Link: http://www.departmentzero.com/downloads/RSRConv.zip
I normally do a 91 x 91 render of whatever I want to make into an RSR, and save it as a PIC file. I then delete the alpha channel in the PIC and use RSR Converter to turn the PIC file into an RSR. I then distribute the RSR and Pro Pack creates it's own PNG from it. Straight P4 uses the RSR. If P5 doesn't convert the RSR into a PNG like Pro Pack, you could also save the 91 x 91 render as a PNG and distribute it along with the converted RSR.... I have distributed both in the past, and since the file size of each is about 12k, it's normally no problem. RSR converter can be downloaded from the attached link. Hope that helps :) Spectre
SAMS3D ( ) posted Thu, 08 August 2002 at 6:11 PM
I can't thank you all enough for the help, I just don't want to leave the people high and dry, I think I will do it both ways, I just downloaded that file Spectre and hopes I can learn it, but if I can't I will be back for answers from you, thanks again so much for the help.....you are all such great pals....Sharen :-)
yarp ( ) posted Thu, 08 August 2002 at 11:58 PM
Sharen, following your mail I updated Rsr2Png this weekend. With that release the transparent RSR bug is fixed and there's an automatic 91x91 crop (no need to start from a 91x91 picture). It is available in freestuff. Yarp
Yarp - author of P3DO Organizer for Poser
SAMS3D ( ) posted Fri, 09 August 2002 at 4:04 AM
I just downloaded the updated and give it a try, thank you. Sharen
yarp ( ) posted Fri, 09 August 2002 at 11:45 AM
You're welcome, hope it'll be ok that time. Anyway it's a bit late, with the arrival of P5 the RSR pictures need is gonna die progressively. btw I should have told you before of the Rsr2Png update, sorry for the delay. When I saw your thread I realized I had forgot to do this. I'm a bit overwhelmed with projects those days, sorry again.
SAMS3D ( ) posted Fri, 09 August 2002 at 12:41 PM
Yea, I know what you mean, no worry, thanks again. Sharen
