Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 12:20 pm)
The solution isn't very simple, but it's easily overlooked:
Switch the display mode to Cartoon or Cartoon-with-Lines, then render as a one-frame animation.
Animation menu --> Make Movie
Set the Sequence Type to Image Files
Set the Quality to Current Display Settings
Enable antialiasing
Set the Time Span to Start 0:0:0:0 and End 0:0:0:0 (1 frame)
The REAL problem with using Poser's "cartoon render" mode for cel shading is that "cartoon render" mode won't render textures, so everything ends up being delineated in solid colors only -- and if a detail isn't built into the actual mesh of an object, then you won't see it at all in "cartoon render" mode. Therefore, Poser doesn't have a true cel renderer. When I saw the folks at Curious Lab at last year's SIGGRAPH (in L.A.) the ONLY thing I asked them for in Poser 5 was a decent cel shader. They all looked at me dazed and confused, like deer caught in the headlights. I never did understand why my simple request seemed to baffle and confuse them -- especially when you think of how many comic book artists out there use Poser and would probably LOVE to have something that would render out in 2D.
Does anyone know a good method for rendering Cel Shaded pictures. I know Poser has the cartoon view mode, which is more or less what I'm looking for. However, since it is a view mode and not a render mode, you don't get antialiasing, and the ability to save the 2d image. Is there a way to have Poser's renderer do cel shading? The back of my mind tells me there is a way, probably something very simple, but right now I can't figure it out. Maybe I'm just having a Friday moment. Thanks Josh
