If your problem is that the toes stick outside the boots, try moking the toes invisible. I've found that woth boots/shoes that's usually the only way to make a proper fit. Just doubleclick (in Windows) on the item you want to make invisible and remove the checkmark in "visible" and "cast shadow" and you're set :o)
heyas; i've had success with changing the x-scale of the feet and toes. don't change the whole scale, or things will get out of place. then select the shin and try the taper dial, if the shin isn't fitting down into the top of the boot correctly. if you squeezed the foot's x-scale, you may not need to taper the shin, as it may already be tapered by that action. i don't like to turn the feet and toes invisible, because then you can't grab them to pose them. and here's a free hint: if your boots/shoes leap up to your figure's crotch when you conform them, make sure you turn leg iks off ;)
How can i do this? I tried to morph her feet in and calf and it doesnt work things just become deformed incredibly anyone know hot to do this? I tried the morphing boots and Vicki Essentials boots and none will conform correctly. :(
