Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2024 Sep 20 10:50 pm)
Thanks Jackson, it's good to know that people are interested, helps keep the motivation up! Sadly the machine I use to create the texture is having memory problems and behaving very badly (random crashes, lockups, etc) so I'm limited to working with the textures I've got until I get it fixed, hopefully that will be tommorow, but I dunno. I can still get a fair amount done with the textures I've got though...actually I've got an old linux box sitting here with a busted fan that should run fine long enough to make a texture or two. Either way look for something from me in the Marketplace soon, I hope to get a few of the smaller packages done in a day or so.
Hi Huolong, I was thinking of doing that, the textures for the bamboo and the wood include the texture for the rope/vine that is used to assemble the pieces, so there would probably be a little construction kit inluded. That would contain the wood (or bamboo), the rope torus, and instructions on how to assemble objects. I did all of the assembly of those objects in poser so it really is quite easy, and that will allow people to create matching objects that they may want and I didn't model out. My other computer is still broke, which is slowing me down because it's the only one with a copy of blender that has the decimate function, which I need to finish a stump I am working on. That will probably be the first set, A log cabin A stump (for sitting people, things on) The bench above The campfire logs above A pier and a raft that can also be used as a pier extension With the log construction kit included as well. That will be all of the things that I plan on building with the wooden logs so people won't have to download the same texture more than once for those.
