Tue, Nov 26, 5:22 PM CST
Subject: How do I making mirrow reflections on a floor??
antovasa ( ) posted Sun, 25 August 2002 at 10:35 AM ยท edited Sat, 23 November 2024 at 1:06 AM
How do I making a mirrow reflection from Victoria on a floor??
thgeisel ( ) posted Sun, 25 August 2002 at 11:30 AM
you cant do that in poser( maybe in poser 5) you need a real raytracer or you have to fake it in a image edit program
Roy G ( ) posted Sun, 25 August 2002 at 11:50 AM
There is a trick where the floor is made somewhat transparent and a mirrored and upside down room and characters are below the floor. I'm not sure exactly what the settings should be though as I have not played with this yet.
Roy G ( ) posted Sun, 25 August 2002 at 12:51 PM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=236724
I had a project open in Poser and decided to try what I mentioned above. Here is an Image of my Space Girl and new FREE Space Ball over in FreeStuff. The floor is actually a Flat SpaceBall with the transparency set to 60%. The link is for the gallery post that I made earlier.
Little_Dragon ( ) posted Mon, 26 August 2002 at 7:16 AM
I haven't tried a mirrored floor (or ceiling) yet.
Video clip (MPEG format, 1.37MB)
100% Poser render. I rendered each reflection separately by placing the camera behind the mirror. Once I had the video rendered, I flipped it horizontally so it would be a true mirror image, then moved the camera back into the studio and imported the "reflection" video as a background animation.
It's a simple trick when the camera is stationary, but a nightmare to get everything aligned properly when you add camera movement.
To get a mirrored floor effect, I'd make the floor invisible, stick the camera underneath, render the "reflection", then flip the image vertically and import it as a background. Then I'd put the camera above the floor, align it so the background lines up with the characters and setting, and render the final image.
Spanki ( ) posted Mon, 26 August 2002 at 11:40 AM
Wow! Very clever, Little D. I can just imagine the grin on your face as this thing came together. Excellent work! BTW, (way off topic) did you ever use a terminal program called Access! ? (just curious).
Cinema4D Plugins (Home of Riptide, Riptide Pro, Undertow, Morph Mill, KyamaSlide and I/Ogre plugins) Poser products Freelance Modelling, Poser Rigging, UV-mapping work for hire.
Little_Dragon ( ) posted Mon, 26 August 2002 at 10:46 PM
No. Why? Was it for the Amiga?
Spanki ( ) posted Mon, 26 August 2002 at 11:08 PM
Yes... I cut my 'C' teeth on writing that program (had been doing Basic and Assembler before that) ;).
Little_Dragon ( ) posted Tue, 27 August 2002 at 8:30 PM
I never got any further than BASIC, Fortran, Logo, Pascal, RPGII, Cobol, and a little Assembler, myself. I wasn't an Amiga user; I'm just a fan of Eric Schwartz's artwork and characters.
Spanki ( ) posted Tue, 27 August 2002 at 8:57 PM
Ahh... ;). I just noticed the Amiga checkmark on your character's t-shirt.
