Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=236724
I haven't tried a mirrored floor (or ceiling) yet.
Video clip (MPEG format, 1.37MB)
100% Poser render. I rendered each reflection separately by placing the camera behind the mirror. Once I had the video rendered, I flipped it horizontally so it would be a true mirror image, then moved the camera back into the studio and imported the "reflection" video as a background animation.
It's a simple trick when the camera is stationary, but a nightmare to get everything aligned properly when you add camera movement.
To get a mirrored floor effect, I'd make the floor invisible, stick the camera underneath, render the "reflection", then flip the image vertically and import it as a background. Then I'd put the camera above the floor, align it so the background lines up with the characters and setting, and render the final image.
Wow! Very clever, Little D. I can just imagine the grin on your face as this thing came together. Excellent work! BTW, (way off topic) did you ever use a terminal program called Access! ? (just curious).
Cinema4D Plugins (Home of Riptide, Riptide Pro, Undertow, Morph Mill, KyamaSlide and I/Ogre plugins) Poser products Freelance Modelling, Poser Rigging, UV-mapping work for hire.
How do I making a mirrow reflection from Victoria on a floor??
