Mon, Nov 25, 2:15 AM CST
Subject: Large Tattoo Across the Seems
willdial ( ) posted Mon, 26 August 2002 at 9:50 PM · edited Mon, 25 November 2024 at 2:06 AM
I have been working a on a way to get large tattoos to cross the seems of the figures. Here is my first serious attempt with a technique that envolves streching the tattoo image to fit seems better. I know it is not perfect but it is better than the other stuff I have made. I would like your opinion and any recommendations. So, What do you Think?
TrekkieGrrrl ( ) posted Tue, 27 August 2002 at 1:06 AM
Whoa...how did you do that? Remapping or what? It looks GOOD!!! (Well not the tattoo G it's too "transfer like" to me but the technique! WOW!)
Anthony Appleyard ( ) posted Tue, 27 August 2002 at 6:43 AM
I had that problem with uniform shoulder badges. I cured it by re-texturemapping the figure so that each arm on the texture map is one piece, vertical, split along its underside only.
bikermouse ( ) posted Tue, 27 August 2002 at 7:09 AM
wilddial, I've been looking at doing tats again over the last week or so - but lower on the arm. The one person who commented noticed the same thing. "too transfer like" to quote ernyoka. Also there is the problem of translating a flat surface to a nonflat one which I haven't yet tackled. It is hard to judge how well your method works without a referance to the original flat picture, but from what I see, Its ok. Also it is hard to judge how large the tatoo is going to look on the body - I noticed the same thing on yours that I noticed on mine - it's too large. Also Poser blends the colors between the bitmap and whatever color is used for the skin in materials and I think this adds to the "transfer-like appearance." If you are not around people with new tatoos you don't realize how "transfer-like" they can look when new. The "faded" look might appeal to most people as looking more natural. - TJ
bikermouse ( ) posted Tue, 27 August 2002 at 7:12 AM
Anthony, You should write a tutorial on how to do that. - TJ
Anthony Appleyard ( ) posted Tue, 27 August 2002 at 7:14 AM
I used a texture map annealing feature which is in my MAKEOBJ utility.
bikermouse ( ) posted Tue, 27 August 2002 at 10:14 AM
Anthony, I dounloaded the MAKEOBJ Utility and will play around with it some later today. Thank you, - TJ
willdial ( ) posted Tue, 27 August 2002 at 12:21 PM
That is not a remapped vicki. I have been working a on trying to get a large tattoo across the seems for quite some time. Bikermouse, Thank you for comments they have helped. I will work on a way to make them a little warn in to combat the "tranfer" look. I like large colorful tattoos. So I work on large tattoos for poser. To each his own. Thank you all for your comments.
