Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Poser can natively export .3ds files for figures or props. They will be non-posable though. The ProPack has plug-ins that will export poser scenes for use in Max. I haven't tried it but I understand that it sets up the figures so they are poseable in Max. If you want to go this route, I'd check the CL website for info on the plug-in just to be sure.
Attached Link: Crossroads
The CrossRoads utility can convert between OBJ and 3DS (and other formats), it's free:Attached Link: http://www.anim8or.com/
Oh, well the most used format for Poser stuff is the .obj. There are several freeware modeling programs that will export .obj files. One that I've tried and works well for Poser is Anim8or. I've attached the link. The front page is a little screwed up right now but if you go to the download area you'll find the newest release.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Is there a utility out there for converting the file format that Poser saves as into a file format that 3DS Max can import/open?
