Forum Moderators: RedPhantom
Yes. They have the same UV-mapping, so the textures work on both. The full version also has MAT files for your texturing convenience, the ERC dials for easier posing, and a bunch of add-on props (additional spikes, tail tips, and other pointy bits). The full version includes the LE dragon, so save DAZ some bandwidth if you're buying. Looks like the server took another beating.
Looks like the site is over loaded, and the new way of shopping takes a bit of learning...so I am going to wait impatiently till TUESDAY (HOLIDAY MONDAY REMEMBER!!) when I can call DAZ if I have trouble.. but bet it is all fixed by then.. this IS the ultimate dragon!!! ooooooo!! Lyne
Life Requires Assembly and we all know how THAT goes!
Hmmm. I was under that impression myself. I initially overlooked the line on the Millennium Dragon page that stated that it included the LE version, and only noticed it later, after I'd already purchased/downloaded both versions. I installed the LE version first, of course, so it was already on my system when I installed the full version. You're right, though. The LE cr2 isn't included in the full version. I suppose that message on the page just means that the Millennium Dragon has the geometry and all the features of the stripped-down LE. If you don't feel like downloading the LE dragon, you could strip all the morphs and ERC code to make your own, but that might take some work.
Poser 9 SR3 and 8 sr3
Processor Type: AMD Phenom II 830 Quad-Core
Hard Drive Size: 1TB
Processor - Clock Speed: 2.8 GHz
Operating System: Windows 7 Home Premium 64-bit
Graphics Type: ATI Radeon HD 4200
System Ram: 8GB
I'm not an expert, nor do I play one on TV, but ....
ERC (Enhanced Remote Control) is an advanced CR2 technique that gives you better control over a figure.
For instance:
Partial body morphs: many morphs linked to one control dial and activated simultaneously
Joint-controlled morphs: morphs linked to joint movement
EasyPose: complex poses generated by a single control dial
In the case of the dragon, ERC is used in many places to make the wings, neck, and tail more easily posable (fold or flap the wings with just one dial!); to link the poseable jaw to the head for Mimic-compatibility; and other stuff I probably haven't noticed yet.
Robert Whisenant (rbtwhiz) is one of the pioneers of ERC; he has a tutorial on his website if you want to delve into the technical aspects of this ... uh ... technique.
I bought the texes & LE dragon, saving the full version for next weekend. If you're going to do this too be aware that the texture pack doesn't seem to include the wing membrane transparency map, though it should be easy enough to create a simple one of your own. I managed to figure out that you had to switch the forked tongue's visibility on and the regular tongue's off for the echt reptillian look, but has anyone found a way to hide the fact the forked tongue originates in the middle of the lower jaw when the mouth is open?
Oh lord, brace yourselves for a flood of Naked Dragons in skimpy armor fighting mean Vickies and Stephanies in temples for the next few weeks......- Wait, I meant the other way around. I think I had too many Corona's this holiday weekend
Software: Daz Studio 4.15, Photoshop CC, Zbrush 2022, Blender 3.3, Silo 2.3, Filter Forge 4. Marvelous Designer 7
Hardware: self built Intel Core i7 8086K, 64GB RAM, RTX 3090 .
lmao JV!!
System Ram: 8GB
We're going to need a larger temple. RHaseltine: You can use the MAT files to give the dragon a small, forked, reptillian tongue, or you can set the individual dials manually. So you could still have the larger tongue that originates at the base of the throat, with a forked tip. The full Millennium Dragon comes with a wing-membrane transmap, so once you have that, you're all set.
that's it exactly, extra morphs, textures & poses, the textures can be used on the LE version just the same as the morphed version. Rob
