Thu, Feb 6, 2:46 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 06 11:58 am)
Subject: Converting Lightwave objects into conforming Poser files
ziewe ( ) posted Thu, 05 September 2002 at 8:51 AM ยท edited Thu, 06 February 2025 at 2:43 PM
I have created a complex item of clothing in Lightwave and would like to import it into Poser with all its posible parts. Does anyone know of a tutorial which explains the process?
ronmolina ( ) posted Thu, 05 September 2002 at 9:14 AM
I dont know of any good tutorials but I do it all the time. It also depends on what version of LW you are using. If 7.5 you can just export the file in obj format, assuming you have defined the parts and grouped them properly in LW. Earlies versions I would chop up my mesh into the varios body parts and export each as an object naming them peoperly. Then I would import each part into poser and export as one mesh in object format welding the parts. This works well. Also depends on what Poser version you are using. If the pro pack then reimport your complete object and go into the setup room and set it up. Find a cr2 that is close to the same body parts so you dont have to set the whole thing up. Hope this makes since. Ron
SAMS3D ( ) posted Thu, 05 September 2002 at 9:19 AM
Attached Link: http://www.meshbox.com
Just so you know I am working with a beta version of a new product that will be available soon, the beta version is downloadable for free, it will convert your Lightwave to any version you would like. You can find the link here, it is called Meshbox.....you may want to try it.
SAMS3D ( ) posted Thu, 05 September 2002 at 9:20 AM
That is if Ron's way doesn't work for you. :-)
Asciicodeplus ( ) posted Thu, 05 September 2002 at 9:23 AM
In the free section of daz3d webpage you can find some useful scripts for lightwave that can help you to do some work around...(they say that they use lightwave to do most of the works they have) (~_~) Ascii
the3dwizard ( ) posted Fri, 06 September 2002 at 8:17 AM
Attached Link: http://arthur.renderosity.com/messages.ez?ForumID=440&Form.ShowMessage=828232
If you have pro pack I discuss the method in brief in the thread at this link. I started with a mesh from Character Creator but any mesh will do. Even clothes from Lightwave.
poserpro ( ) posted Fri, 06 September 2002 at 2:11 PM
For SAMS3D, please mail me at julien@arrowweb.com about meshbox issue. THX in adv.
