Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 13 3:34 pm)
Gee I thought I did a better job of getting this guy's likeness than this. This is not very encouraging. If it helps disregard the hair because there really isnt a Poser hairstyle that matches his (not without a lot of tweaking). I dont want to give any hints because that will spoil all the fun. Thanks, Dave
Well Kevschmev you hit the nail on the head. Which morph in particular. I've pulled out the stops on the morphs and this is as close as I could get. Point me in the right direction to the problem area and I might be able to tweak it some more. Eyeballs arent gleaming white in the texture map. The lighting is over-emphasizing it. I was trying to copy the lighting setup from the photo and evidently I have the lights too bright. Sorry.
Well, I could tell that it was suppoed to be David Duchovony. Mostly from the lips. I think the real david's head is a bit less narrow... I'd reduce the y-scale, OR widen the head/face, or turn "facelong" down, or maybe make the jaw more full. It's hard to say without actually seeing the effect of the dials. Good Luck! -MagnetMage
Yeah, I see the resemblance now... Now looking at the pic, the face and nose are too long and his eyes need to be bigger and a little closer. Nose hump is too prominent. Lips look about right. It will take alot of time to get the proper look. My Niki character I did took me over 30 hrs of playing with morph dials to get just right and the other characters I am working on are taking alot of time as well. I need to get back to work on them. =P
Do you have Poser 5? This is a prime candidate, and would be a great test, of the Face Room. I think you would get much better results a LOT faster.
I'd be the first one to tell you the Face Room is far from perfect, but it would make quick work of the basics for his face (general shape ... and texture map especially) and you could spend the saved time tweaking the morphs to death.
You'd need a profile shot of him as well at a decent res, but that would be far from impossible given his major Star Factor.
-Tim
