Sat, Jan 25, 12:32 PM CST
Subject: Do you want clothes for the PreTeens? look here...
shadowcat ( ) posted Fri, 06 September 2002 at 4:32 PM · edited Fri, 10 January 2025 at 8:16 PM
Packing this up to send to poserstyle. If it goes into freestuff, mover will be required. I fitted both the archer tunics & vicky's leggings to the preteen girl! Just 1 more reason to get a subscription. (boots are scaled to 82% ten I made the legs invisable & tapered the pant)
shadowcat ( ) posted Fri, 06 September 2002 at 4:37 PM
The other tunic (by the way if you want the PreTeen to have breasts for an elf or fairy, then copy the morph "breast gone" from vicky2 & set to -1)
Aureeanna ( ) posted Fri, 06 September 2002 at 5:11 PM
OUTSTANDING!!!! drooling
Kalypso ( ) posted Fri, 06 September 2002 at 5:24 PM
Site Admin
These look great! Thanks, would the same settings then apply to all clothing items? I'm thinking of the Medieval dress at Poser Style.
shadowcat ( ) posted Fri, 06 September 2002 at 5:34 PM
No, the preteen girl's arms are bent forward a little & the belly sticks out. Making the clothes fit requires changes to the base .obj thinking about making a tutorial for doing it, but here's the quick run down. import the .obj into poser, all boxes unchecked except "weld identical vertices" scale the object to 75% & line up to the preteen in zero position (turn off inverse kin., set the y trans of the body & the hip to zero & zero the pose with joint editor) once the .obj is position to the preteen you then need to use magnets where skin pokes through (tummy & arms) save the .obj (boxes 1, 3 & 4 checked) & edit a .cr2 to point to it.
shadowcat ( ) posted Fri, 06 September 2002 at 5:57 PM
oops - scale the .obj to 79% not 75%
geep ( ) posted Fri, 06 September 2002 at 6:18 PM
Very nice work! ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Roy G ( ) posted Sat, 07 September 2002 at 12:09 AM
Thanks for those usefull tips Shadowcat! I want to try this.
pendarian ( ) posted Sat, 07 September 2002 at 12:19 AM
Darling outfits!! What clothing do you need to have in order to use them? Pendy
Dreamspinner ( ) posted Sat, 07 September 2002 at 1:04 AM
Would certainly like to see that tutorial if you have time to write it. Liz Pope Dreamspinner
lemur01 ( ) posted Sat, 07 September 2002 at 2:15 AM
Way cool, just the sort of thing I've been looking for. Jack
d_authority ( ) posted Sat, 07 September 2002 at 7:26 AM
yeah i want that one. but then again, i can't seem to get a subscription to poserstyle. :(
queri ( ) posted Sat, 07 September 2002 at 2:58 PM
Fantastic and absolutely needed by me. I just happened to need some fantasy garb for the pre-teen boy. I am hoping it works on the boy??? The top one should work well, actually. Fortunately I do have the items from PoserStyle, although I'm having some probs at their site right now. Maybe my membership has expired, but I though it was good till Oct. Emily
shadowcat ( ) posted Sat, 07 September 2002 at 10:32 PM
Well, I sent it and it apparentlly has joint problems with the thighs on the mike tunic. The pant & vicky tunic has no problems. Once it gets fixed it will be in the members area so there will be no messing around with mover! Unfortunatlly those 2 joints are giving me trouble. I might just make the "skirt" portion a solid part of the hip and make morphs for leg movement. (if I can't get it fixed soon, grrrr...) PS - for those peole whose subs have expired, don't panic, arrangements will be made. But go see the previews of coming releases, there are some great items slated.
