No, the preteen girl's arms are bent forward a little & the belly sticks out. Making the clothes fit requires changes to the base .obj thinking about making a tutorial for doing it, but here's the quick run down. import the .obj into poser, all boxes unchecked except "weld identical vertices" scale the object to 75% & line up to the preteen in zero position (turn off inverse kin., set the y trans of the body & the hip to zero & zero the pose with joint editor) once the .obj is position to the preteen you then need to use magnets where skin pokes through (tummy & arms) save the .obj (boxes 1, 3 & 4 checked) & edit a .cr2 to point to it.
Fantastic and absolutely needed by me. I just happened to need some fantasy garb for the pre-teen boy. I am hoping it works on the boy??? The top one should work well, actually. Fortunately I do have the items from PoserStyle, although I'm having some probs at their site right now. Maybe my membership has expired, but I though it was good till Oct. Emily
Well, I sent it and it apparentlly has joint problems with the thighs on the mike tunic. The pant & vicky tunic has no problems. Once it gets fixed it will be in the members area so there will be no messing around with mover! Unfortunatlly those 2 joints are giving me trouble. I might just make the "skirt" portion a solid part of the hip and make morphs for leg movement. (if I can't get it fixed soon, grrrr...) PS - for those peole whose subs have expired, don't panic, arrangements will be made. But go see the previews of coming releases, there are some great items slated.
