To create the materials, you can either use the heirarchy editor or the grouping tool. I tend to use the grouping tool for this sort of task. Start the tool and select all of the polygons for the blade (it's best to do this in wireframe mode) and assign a material. Then do the hilt, guard, and any other parts. Then create a new prop. You might have to export the prop and remap it in UVmapper to get the textures to fit properly. Unfortunately, there isn't a glow-channel in Poser. You can do it post-render in PS, or render in Bryce to get the glow. Paul
You should make the blade ambience white (or the color of the glow), then add to the blade a prop that duplicates the blade (use a 3d program or the grouping tool and "spawn prop") and is a little bigger. Make the duplicate a little bigger and make it transparent and glow-colored. With a max/min 50% transparency it will be translucent, but its shape will be hard (you'll have to soften it in post retouching). I'm working on a firearm burst fire and a min 100% and max 50-75% give good results, but not accurate. I still haven't checked Ferret's tutorial, so he may have a better solution.
I'm trying to make a blue glowing sword (Twinkle),can this be done in poser? Also I'm trying to apply the tex map to just the hilt of the scimitar (so I can use a reflection map on the blade)but it applies to the whole thing. There are no materials to choose from (its just one whole thing). Is there a way to change it so I can separate the blade from the hilt? Or is there a way to apply a reflection map to just part of the sword the way it is? thanks for any help:0)
