Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
The amount of work and composition is terrific, most definitely continue! A slight letdown is some horizontal shadow lines across the figures and something unidentifiable on the floor forward of the table? Perhaps a Bryce user could give some helpful lighting advice in that area or you might be able to try rendering with the Vue d Esperit 2 program on the cover disc of the latest Digit magazine. Keep at it, I'll be keen to see your finished result. Tommy.
The light is coming through a window which is out of view, just giving shadows of the glazing bars across the scene. I was sort of aiming for one of those wonderful summer early evenings, with a westering sun creating shadows. Obviously it is not working well.
The greatest part of wisdom is learning to develop the ineffable genius of extracting the "neither here nor there" out of any situation...."
It looks nice! I like the little details you put in the scene. The wall on the left looks a little bit empty. Maybe you could put some paintings there? Or, what if there was a window on that wall and that's where the light would come from? That would explain the shadows on the floor. Of course, I know there's a door with a character peeking in there (which is a really nice touch), and you can see that there's another room there, so I'm not sure if that would really work well...
Just two tiny things (because this is really spectacular): the bottle looks like it's about to fall off the table. You might want to pull it back. And the shadow it casts on the floor makes everything else look out of scale -- in RL, that shadow would have diffused, if not outright disappeared from the effect of the other light sources. I think you can lose it and not miss a thing. I might pump up the dancers' reflections a tad and, as someone else suggested, put some paintings on the laft wall (big ones, to completely fill the space, as they did in that period). But good job!
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=243598
Had to render it in Bryce, couldn't get this much in poser, is it worth persevering with. No postwork. Dresses from poserfashion, men clothed by poserworld, textures mine.The greatest part of wisdom is learning to develop the ineffable genius of extracting the "neither here nor there" out of any situation...."
