Tue, Feb 25, 11:36 PM CST
Renderosity Forums / Fractals
Welcome to the Fractals Forum
Forum Moderators: msansing
Fractals F.A.Q (Last Updated: 2025 Feb 18 8:05 am)
Subject: UF3 + ENR Flame ucl = Thread Out of Memory error?
jockc ( ) posted Mon, 09 September 2002 at 4:21 PM · edited Thu, 20 February 2025 at 1:38 AM
Is anyone else besides me getting these? I have 384 meg at work and 1 gig at home and I get these errors on both machines. Even if I replace the gradient (when you import a UPR from Apophysis it has about 200 points) with a simple gradient with 3-4 points, I still get these errors.
pennylane ( ) posted Tue, 10 September 2002 at 2:03 AM
yes, from what i've tried myself, and what i've seen on the ultrafractal list, the flame ucl is extremely memory intensive and will max out most all systems...
fayrelady ( ) posted Tue, 10 September 2002 at 2:03 PM
I had this message when rendering to disk, didn't know what it meant so I just kept closing the little box till the rendering finished, luckily it still turned out fine.
Deagol ( ) posted Thu, 03 October 2002 at 8:08 PM
Hi, My first post in this forum.
So, my trick to avoid the memory error is to go lightly when adjusting the gradient. Make a very quick adjustment then wait for the calculation to complete before making the next adjustment. I have also found it helpful to use the Gradient- adjust colors panel. This works for me. I hope it does for you too.
mt has stated several times on the UF list that it is not a good idea to render flames to disk. I think he said that anti-aliasing wasn't designed for flames and that they just take up too much memory. Hope this helps
