Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 22 5:13 am)
I'm not sure if it works, but I think you'll have to have a reflection map that matches the transmap, so that the invisible parts of the transmap are black on the transmap as well. This way it outta work, but I can't try it as I 'm at work, without Poser :o(
I only tried this on a Poser square, they don't take well to reflection maps, so it's hard to judge the result.
is it possible to use reflection and trans maps at the same time? the areas that are supposed to be invisible are made partially visible by the reflection map. this is also true if the highlight color isnt set to absolute black. is there a workaround for this?
