Fri, Feb 14, 11:22 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
Subject: poser executable file
soc_inter ( ) posted Thu, 12 September 2002 at 12:38 PM · edited Wed, 12 February 2025 at 6:10 AM
( Poser 5 )When I tried to register it, I got my challenge code and my response code and I printed it. When I click finish to close the window, a message error occur and said that Poser executable file has encontered a problem and needs to close. Well I can not open it since that. I got windows xp Did I do something wrong ?
c1rcle ( ) posted Thu, 12 September 2002 at 12:43 PM
have you tried reinstalling?, the challenge & serials will be the same
soc_inter ( ) posted Thu, 12 September 2002 at 12:49 PM
yes I tried it
c1rcle ( ) posted Thu, 12 September 2002 at 12:53 PM
the last time I had that sort of error it was a virus, but I don't think that's what this is, how about changing the compatability settings to windows 98, see if that changes anything
soc_inter ( ) posted Thu, 12 September 2002 at 12:56 PM
Before changing to windows 98, should I format my hard drive ?
c1rcle ( ) posted Thu, 12 September 2002 at 12:59 PM
NOOOOOOOOOOOOOOOOOOOOO! all you need to do is right click on the poser exe file, choose properties, then choose the compatability tab & change that to windows 98
soc_inter ( ) posted Thu, 12 September 2002 at 1:12 PM
I tried it and the answer was : Initialisation error unsupported driver call. Does it mean that I can only install poser 5 on drive C because I installed it on the drive E
c1rcle ( ) posted Thu, 12 September 2002 at 1:16 PM
that doesn't sound too healthy, try to install poser5 on the C drive if that doesn't work I'd fire off an email to the tech bods at Curious. you might need to repair XP, but try the install of poser first
elektra ( ) posted Thu, 12 September 2002 at 1:16 PM
I have Poser on my D drive and it registered just fine. Do you have a firewall app like Zone Alarm? Did you allow the Poser.exe through?
c1rcle ( ) posted Thu, 12 September 2002 at 1:19 PM
damn I didn't think of that, so used to firing up the wall & ignoring it I forget it's there
soc_inter ( ) posted Thu, 12 September 2002 at 1:42 PM
No I don't have a firewall. I will try to reinstall poser on the C drive. Thanks a lot
wdupre ( ) posted Thu, 12 September 2002 at 1:49 PM
XP has it's own built in firewall see if that is on.
soc_inter ( ) posted Thu, 12 September 2002 at 2:34 PM
Thanks a lot to every one who helped me. I reinstall poser 5 on the c drive and it works just fine. Thanks again
WiNC ( ) posted Fri, 13 September 2002 at 7:30 AM
You might want to make sure you haven't got NTFS compression on - if you do have that on in any other your drives it can cause issues with certain operation calls. I have had simular experience with certain games refusing to work on NTFS compressed drives... WiNC
