Forum Moderators: RedPhantom
I need to tighten the top layers up, and add a solid base. Also the quickie map I made is rather nasty at the top. In the end it will be morphable and poseable. I only have an hour of actual work into this right now, (weeks of thinking about the problems of making the mesh though) it will get better :) -Trav
It looks pretty good, in many ways better than mine, and I've got weeks of work in mine! Maybe I'm expecting too much, hair is really just too tough with the tools we have now, the layers are only 2D, and if you can see them on edge they have no thickness, and if if you have too many you really can't see through them like you can on real hair. Maybe I'll go on to something else for now, and come back to this some other time. Maybe a better answer is put the detail in in the model- The modification to the Poser Hair that someone did (maybe you?) called "morph hair 5", the one that covers one side of the face, looks pretty good to me, second only to Allie's hair in my opinion (and better than than the other free hair that everybody uses),and it renders faster, too!
Here is what I have for my transmapped hair project. Tech info: 16 Pieces, put together to form 4 tight layers. (I made the layers in pieces of 4 to ease the uv mapping. Each layer has its own material set, with the colors getting darker as you go down through the hair. All layers are set at 0 min 100 max, but the maps for the layers are "thinner" aka more grey and black at the top levels. I know she is looking scruffy, this was a test of the mesh really. -Trav
