Wed, Feb 12, 6:11 AM CST
Subject: Bad (P4) hair day in P5.....
Lucy_Fur ( ) posted Sat, 14 September 2002 at 1:29 PM ยท edited Fri, 15 November 2024 at 12:46 AM
Can someone tell me what this is about??? You can see the obvious problem, but the texture map is fine - why the blocky,different colored looking sections of hair in the two P5 render settings?
wdupre ( ) posted Sat, 14 September 2002 at 2:12 PM
Perhaps it is a problem with the way the material room imports the P4 transparency settings?
Kiera ( ) posted Sat, 14 September 2002 at 2:43 PM
When I rendered with P4 hair i had to change the transparency falloff from .6 to 0 in the materials room.
queri ( ) posted Sat, 14 September 2002 at 2:55 PM
There's a light on top-- is something somewhere throwing a shadow? Emily
Lucy_Fur ( ) posted Sat, 14 September 2002 at 3:17 PM
The lighting is Blackhearted's Soft Light global illumination - you can see how each renderer handles it a little differently (most notable in the hair in this image).
I tried your suggestion, Kiera & it didn't pan out for me :(
btw - the hair I'm using is the Elleana hair if anyone else has it and wants to see if it turns out that way for them as well.
Kiera ( ) posted Sat, 14 September 2002 at 3:26 PM
Do you have backfacing polygons checked?
Lucy_Fur ( ) posted Sat, 14 September 2002 at 4:21 PM
Pulled up Anton's hair because it's so versatile & did renders of 3 different styles - long, short & up.
In the long, you can see where firefly seems to be reading the texture map wrong - but it's fine in the P4 render.
In the short, both images seem to be similar - no obvious texure problems in the firefly render.
In the updo, it appears to be okay except in the top wisps (firefly) - P4 render is fine.
And yes, backfacing polygons is/was checked
Kiera ( ) posted Sat, 14 September 2002 at 4:37 PM
Try unchecking it.
