Mon, Feb 10, 4:02 AM CST
Subject: Problem w P5 (fix included!)
Jackson ( ) posted Sun, 15 September 2002 at 1:17 PM ยท edited Mon, 10 February 2025 at 3:50 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=870417
I saved Cousin It last night just as he was when I first posted him (see link). When I reloaded the file today, this is what it looked like (see pic). Now, believe it or not, Cousin It is just a ball prop with hair grown on it (it kills me to have to let that secret out). It appeared at first that the ball had dropped to the ground. But upon selecting the ball, its Ytrans dial was still set to 3.something. The glasses and hat are 3.something, too. So I tried to raise the ball; it wouldn't budge. Couldn't move it in any direction. So then I selected the hair and its dial was set at zero. I raised the hair and wa-la, it worked. And the ball went with it. Is that the way it's supposed to work? I didn't see that in the manual, but if it is, why didn't it do that when I first came out of the hair room? Another question, is everything with hair on it going to be pushed to the floor when you save it? And what about the X and Z locations? I just thought of these questions now, or Id'a checked that before I posted this.
ronmolina ( ) posted Sun, 15 September 2002 at 1:32 PM
I believe the manual says that you have to redo the dynamics for hair and cloth each time you attempt to reuse them. This is standard in most other apps I have. Ron
ronmolina ( ) posted Sun, 15 September 2002 at 1:34 PM
One other thing with hair and saving. Save the scalp also. Ron
redon634 ( ) posted Sun, 15 September 2002 at 1:36 PM
The only real bug (at least I don't think it's me, but you never know) that I've noticed with P5 is similar to this one - the hair I've created has a tendency to zero itself when I save the project. If I exit Poser, start it up again, and reopen the project, the hair is back in place (unlike yours). This was hair I had created on a skullcap, so it's a prop like Cousin It.
pzrite ( ) posted Sun, 15 September 2002 at 4:25 PM
When you save and the hair zero's out (or moves halfway off the screen), just move the camera a little bit and it will be back in place. You don't have to close and reopen the file.
redon634 ( ) posted Sun, 15 September 2002 at 5:58 PM
Thanks! That will save some time.
timoteo1 ( ) posted Sun, 15 September 2002 at 11:23 PM
BOOKMARK!
Jackson ( ) posted Mon, 16 September 2002 at 6:45 AM
Thanks for the tips. Ron, I knew to redo the dynamics after each pose, never thought to do it when reloading the file. And it's too late to try it cuz I'd already fixed it. And the ball has no scalp. But it was the scene I saved, not the hair. pzrite: I moved the camera all over the place, nothing changed. The only way I could fix it was to move the hair up with the Ytrans dial. It's strange, too, because the hair is a child of the ball. I thought it had to follow its parent, not the other way around. In any event, I animated it and it worked fine. It took 20 frames for the hair to stop moving at the end, though.
