Kelchris3, I'm with you, started with Poser 3, from the magazines and upgraded to P4 in short order, never heard a word about not using the menu functions! Seems to me THAT should have been in the manual somewhere. I've used them several times on the Poser 4 figures with decent results. Come to think of it though, I don't remember if I ever tried them on Vicki or Mike. Thanks for the info! mike
Re-read the manual section on the menu bar. It explained that "Poser provides several figure heights, which you can adjust by selecting...". It then goes on to explain that the heights are measured in "heads" etc. At no point does it mention anything about P2 or that this menu option is NOT for P5 characters. The fact that Foxhollow says (and I have verified) that this happens using normal translation scaling leads me to believe it is related to the missing FBMs on the new figures. This is not a slam against CL or Poser 5. For the most part I seriously like the program. I just want the figures to have their full usefulness. If this isn't supposed to work with the P5 figures, perhaps Anthony can clarify that point. Otherwise I think it's a bug that needs to be reported. If it is related to the FBMs that are missing then the sooner CL releases them the better. I believe in CL, and I do believe that they are coding a repair patch for many, or all of the known bugs. However, a show of good faith on their part certainly can't hurt with all of the bad talk currently circulating. mike
I have seen mention in previous posts that CL is aware of the FBM problems and are scheduled to be fixed in the first patch...I expect this scaling problem will also be taken care of. Poser 5 IS a major upgrade...one that DESERVES a whole new version number, unlike most other software nowadays! The features they added are major, high level features not available in the box with any 3D software I know of. Time will cure it and They'll get it straightened out.
