Mon, Jan 13, 12:39 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
Subject: should I... with this creature???
Glas ( ) posted Sun, 22 September 2002 at 9:36 PM · edited Mon, 13 January 2025 at 12:28 PM
As you can see I still have a bit to go with this but I am looking for a bit of input before I go much further. I don't know if I should make the beak part of the head (one mesh) or as a seperate object. The advantage of the one mesh is if I decide to make it posable. less joints and bones to be consirned with. ( this is an assumetion I haven't made a bone set for any thing yet) The disadvantage is texturing and if you use a seperate rendering program the ability would be lose to make the beak glossy. If I did make them four seperate item and would there be a problem in linking and posing? Any other pro or cons? Or even suggestions on what else should be done to the poor creature.
Glas ( ) posted Sun, 22 September 2002 at 9:37 PM
here a close up
Momcat ( ) posted Sun, 22 September 2002 at 9:59 PM
Even if you make it a single mesh, you can still create seperate groups and asign seperate materials, can't you?
micca ( ) posted Sun, 22 September 2002 at 9:59 PM
looke cool
hewsan ( ) posted Sun, 22 September 2002 at 10:47 PM
Like the musculature (sp?) you did in the wings. If you are going to export to obj - for poser - then the texuring will be with a uv map. Having the beak combined then as part of the mesh, then wouoldn't be that much of a hindrance in texturing me thinks.
PheonixRising ( ) posted Sun, 22 September 2002 at 11:54 PM
it does look cool. If you need any advice with joints, not that you would, drop me a line. I love animals. This looks great by the way. Anton anton@daz3d.com
-Anton, creator of ApolloMaximus: 32,000+ downloads since 3-13-07
NEW The Poser FaceInterMixer
noggin ( ) posted Mon, 23 September 2002 at 4:38 AM
I agree with all the above_ you don't need to consider body parts and materials as the same things_ just use the assign material option in Poser or a mapper such as UVMapper. From a poseability point of view I would be inclined to have the upper beak section as part of the head (and therefore fixed) and the lower section of the beak and the tongue each as seperate body parts that you can pose_ it would look more natural. Great modelling btw!
Glas ( ) posted Mon, 23 September 2002 at 5:46 AM
Thank youall for the advice and tips Pheonix I may be dropping you a line in a couple of weeks about the bone set up.
