Sun, Feb 2, 12:40 AM CST
Bryce F.A.Q (Last Updated: 2025 Feb 02 12:16 am)
Subject: Brrrrrrrrrrrrrrrr!
Zhann ( ) posted Tue, 01 October 2002 at 1:45 AM · edited Wed, 22 January 2025 at 9:03 AM
Hi All, I just sketched out some landscapes with snow (yes, I still sketch on paper first), snow on trees, snow on rocks, snow on grasses, snow on everything, and now that I think about it ice too...any tutorials or suggestions on the how's and where's of snow? Any thing is appreciated (I'm just getting the hang of Bryce, these will be my 'first' landscapes) Thanks afore hand...Zhann
Bryce Forum Coordinator....
madmax_br5 ( ) posted Tue, 01 October 2002 at 3:19 AM
Check brycetech.com fire and ice tutorial
Zhann ( ) posted Tue, 01 October 2002 at 3:27 AM
Thanks, will do...:)
bikermouse ( ) posted Tue, 01 October 2002 at 3:57 AM
Zhann, It seems that you can achieve icey terrains by checking light instead of normal rendeer,use light colored procedural textures and increasing bump height in the material editor, but I'm too impatient to test it our. it turned what was a 5 minute quick test render into an 11 hour test render. I aborted before it got through - wish I'd have saved a pict of it now. Just a thought: offsetting a copy of your tree etc., making it a whitish texture and inreasing bump height and combining them as a boolean might work. BTW your gallery images look very good. - TJ
airflamesred ( ) posted Tue, 01 October 2002 at 3:59 AM
yes I heard a similar one Duplicate everything in the scene, group and nudge up slightly - add snow tex
Zhann ( ) posted Tue, 01 October 2002 at 4:39 AM
Thanks TJ for lookin' at my work :), and I'll give the duplication thing a try, BTW, I live in Colorado so snow is here already, and there are great mountains to use as models, kinda got me into thinking snowscene... Zhann
Zhann ( ) posted Tue, 01 October 2002 at 4:42 AM
Can trees be boolean objects? (as you may notice, haven't gotten to that in the manual yet :)...)
bikermouse ( ) posted Tue, 01 October 2002 at 4:48 AM
If the tree is all one group you can boolean that group with another group or object. In B5 I don't know. Trees were one of the things they updated for B5. - TJ
madmax_br5 ( ) posted Tue, 01 October 2002 at 4:51 AM
No, trees in bryce5 have no boolean abilities.
Zhann ( ) posted Tue, 01 October 2002 at 4:54 AM
Yup, I have B5 alright, had to ask here just to find the file menu bar, they failed to mention how to access it in the paperwork, :p...
Zhann ( ) posted Tue, 01 October 2002 at 4:55 AM
Darn!
Zhann ( ) posted Tue, 01 October 2002 at 4:57 AM
Could I just group two trees (different textures), one slightly offset from the other to get the effect?...
bikermouse ( ) posted Tue, 01 October 2002 at 5:10 AM
Zhann, Well it's all an experiment at this point. might as well try it. Can trees in B5 be disassembled in any way? You might be able to work with that if so. If worst comes to worst you could import a tree created in another app unless this is for the all bryce challenge. I think Virtual Tree has a few neat trees in Renderosity's freestuff you could use to try with the ideas presented about booleans. - TJ
Zhann ( ) posted Tue, 01 October 2002 at 5:20 AM
Not for anything special, I do landscapes in acrylic and I wanted to do some digitally, see what can be done in B5...I've done some in Terragen, but I can't get what I'm after...soooo, onward and upward, I'll see what happens, I'll see if I can take 'em apart and reassemble...what could happen after all?...
madmax_br5 ( ) posted Tue, 01 October 2002 at 5:30 AM
You can apply a completely transparent material to the trunk of a tree, then apply ice to the leves and offest it just a little bit.
Zhann ( ) posted Tue, 01 October 2002 at 5:43 AM
Done! Look for a strange image in the next few days or thereabouts, possibly, maybe, just don't laugh...
bikermouse ( ) posted Tue, 01 October 2002 at 5:52 AM
Zhann, If it is half as good as your gallery images, I don't think anyone will be laughing - they will be too busy picking their jaws off the floor. - TJ
Zhann ( ) posted Tue, 01 October 2002 at 5:57 AM
I can only hope to be as good as you guys someday, I've seen some really amazing stuff...
bikermouse ( ) posted Tue, 01 October 2002 at 6:14 AM
Zhann,
I have a looong way to go before I can be considered one of the "you guys". I'm working on it though.
Speaking of which could you check out the star field in
this render for me and tell me what you think of the starfield itself? it's actually a textured dome and I was wondering if it looks even a little bit like a sky full of stars? I mean it looks ok to me but I sometimes fail to be objective about my own stuff.
  • TJ
Flak ( ) posted Tue, 01 October 2002 at 6:33 AM
Looking forward to your pic, Zahnn. I tried a snow pic ages ago, and gave up on the trees in frustration.
Digital WasteLanD
miden1138 ( ) posted Tue, 01 October 2002 at 6:59 PM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=81916&Start=73&Artist=miden1138&ByArtist=Yes
I tried a snow scene once in B5, and I figured out a real easy way to put snow on your trees.
First, take all the leaves off of the tree by reducing the number of leaves in the tree lab to zero. Then instead of using a trunk material for the tree, use a snowy texture from the "Plains and Terrains" group. If I remember correctly, there are a couple that have a rock texture that look a lot like bark. You may have to play with the colors in the DTE and change the texture from "World Space" to "Object Space" for it to work, tho'.
Hold on, let me see if I can find the image...Ah, found it.
If you look closely, you can see the snow on the tops of the branches. If I remember correctly, that's how I did it.
Hope this helps!
Mike
Zhann ( ) posted Wed, 02 October 2002 at 1:06 AM
Mike, great pic, I love the distant mountains, and the tree limbs do look like they have snow on 'em. I was thinking more of coniferous type trees, but now I think I might try a few deciduous also... thanks for the looksee... Zhann
madmax_br5 ( ) posted Wed, 02 October 2002 at 4:07 AM
BTW Zhann, you can make a transparency layer in the material itself.
madmax_br5 ( ) posted Wed, 02 October 2002 at 4:12 AM
Here's a side-by-side of the orginal tree and the "winterized" one. The leaves on the snowy tree have a multilayered texture applied...I will upload them soon so you can mess around with it. The snow on the branches was made by duplicating the tree, then setting leaves to zero, so I just had the trunk and branches. Then I applied the "iceberg" preset under water and liquids. I offset the tree .15 BU up and then moved is slighty away from the camera so the trunk would not have white gunk all over it.
madmax_br5 ( ) posted Wed, 02 October 2002 at 4:30 AM
Oh I forgot...I made the iceberg tree a bit smaller as well. Here's a close-up. You'll notice that it's still not perfect yet, but it works fine for trees at a medium distance.
Zhann ( ) posted Wed, 02 October 2002 at 5:54 AM
Wow, that's really good! I'd love to play around with it. BTW, just for reference, this is what I'm aimming for (see image) do you think it's possible? I took alot of reference photos last winter for acrylic landscapes, but I thought I'd try them in Bryce...
madmax_br5 ( ) posted Wed, 02 October 2002 at 9:19 AM
For that much snow, you might try rendering the tree with a distance mask, then open i in photoshop and stagger is a bit. Then back into bryce import as a lattice, clip, and stick it over the real tree. I will have to try this.
Aldaron ( ) posted Wed, 02 October 2002 at 12:49 PM
This is the best I've come up with so far with about 20 minutes of work. 1. Create (or load) tree from tree lab 2. With tree selected do a distance mask render, save image. 3. Create lattice and go to terrain editor. Load image and invert. Play with smooth and sharpen, etc until you get something nice. 4. Position and size the lattice until the branches are just laying on the tree branches. 5. Apply snow material. Only works from certain angles so may not be good for animations.
madmax_br5 ( ) posted Wed, 02 October 2002 at 10:28 PM
Here's the latest permutstion from me. Unfortunately the render times were way less than fast. This image took 35 minutes and I have a fairly nice machine. I think it is just the material I used though.
Zhann ( ) posted Wed, 02 October 2002 at 10:42 PM
Hey, I like both of those, will try both ways...Oh,BTW anybody need reference photos of stuff just ask, photography is my second artform...
