Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
Interesting, but I think the terminology is not the best. It seems commonly accepted, and logical that one Poser unit = 1.000 on a translation dial, (which by some conventions = 8"). It seems that 1,000 of your PNU = 1 Poser unit, there seems to be a potential here for confusion between a PNU and a Poser Unit.
Senior lesbentley is ABSOLUTELY CORRECT !!!
Dr Geep has made another boo-boo !
[but NOT on purpose - I assure you]
I have arbitrarily defined a PNU as the smallest increment that you can change something in the Poser "studio."
That is, changing "yTran" from 0.000 to 0.001 would be an increment of one PNU.
I believe Mr. lesbentley meant that 1.000 on the Poser dial should be 8' (feet) and NOT 8" (inches).
I have found that using 1.000 to equal 8.333... (repeating decimal) feet works very well because that makes 1.000 equal to 8 and 1/3 feet or 8' 4" or 100" EXACTLY !!!
Thus:
1.000 = 100"
0.100 = 10"
0.010 = 1"
0.001 = 0.1"
This is the scale that my 9' Prop Scale is based upon.
So, I guess I only have 1 square Poser Unit and not 1,000,000.
sniff
BUT ...
I DO still have 1,000,000 squares !
Oh well, it was fun, anyway.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
I wasn't going to mention THAT because it will REALLY "muddy the water" for anyone who is gonna ask,
"Ok, I only can see 3 decimal places on the display, where is the ..., etc."
Wouldn't you agree?
OR - are you are referring to P5?
I would refer you to the original "Subject" of this thread.
Besides, do we really need to measure down to one ten-thousanth of an inch?
1/10 of an inch (using my scale) is the distance that Poser's GROUND is below 0,0,0 (the yTran value).
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
![file_25834.gif](https://live.cdn.renderosity.com/forum/_legacy/file_25834.gif)
I HAD to try it, ... ..................... and IT WORKED !!! cheers, dr geep ;=]Remember ... "With Poser, all things are possible, and poseable!"
cheers,
dr geep ... :o]
edited 10/5/2019
