Anthony,
I'm finding that, if I make the diffuse and specular black, plugging the reflect node into the reflection colour channel still gives artifacts with the simple square-prop mirror.
But, if I plug the reflect node into the Alternate Diffuse channel (as in the example I gave above) then everything seems to work ok. I can't understand why that should be......or......am I missing something..?
Ian
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=871249
Artifacts look similar to the ones I'm seeing in the thread at the attached link. Are you using the two sided plain? Try using the exact same settings with the one sidded plain.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
