Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 7:14 pm)
DO NOT forget to make a backup copy of TPKX.VXD in your WindowsSystem directory prior to installing the P5-SR1 update.
The update overwrites this file and COULD cause both your P4 and P5 fail to startup and yam your PC. Should this be the case: simply restore the backuped TPKX.VXD, reboot your PC and both P4 and P5-SR1 should work fine.
You can find further info at Curious Labs`s twchnical support page.
Happy posing!
MaxxArcher
I'd heard the same thing for W2k. I installed the pieces separately on my XP machine and it's running much better than unpatched. Personally, I figured it would be better to do them separately just in case I ever needed to restore some figures from the library without redoing the whole installation or patch job.
I downloaded the patches separately and It worked fine. I'm using Win2k. The sepatare download was mainly because I couldn't get the full version to dowload, so I dodn't try it. But I know the separate download worked for me. Someone here said it didn't matter which order you installed them, but I installed the 'apps' patch first and the 'figures' patch second. No problems so far.
If anyone is having problems updating poser 5 with the full service pack, you should try the seperate updates. The full update didn't work for me but the seperate updates worked fine. Running XP pro. Regards, Doug
