Sat, Feb 8, 9:48 AM CST
Subject: Poser 5 SR1 full VS. seperate updates
dougj ( ) posted Sun, 06 October 2002 at 1:53 PM ยท edited Sat, 08 February 2025 at 4:37 AM
If anyone is having problems updating poser 5 with the full service pack, you should try the seperate updates. The full update didn't work for me but the seperate updates worked fine. Running XP pro. Regards, Doug
praxis22 ( ) posted Sun, 06 October 2002 at 2:06 PM
Good to know, cheers!
Terry Mitchell ( ) posted Sun, 06 October 2002 at 3:21 PM
How about the full versus separate updates wprking in W2K? Anyone?
Intel Core I7 3090K 4.5 GhZ (overclocked) 12-meg cache CPU, 32 Gig DDR3 memory, GeoForce GTX680 2gig 256 Bit PCI Express 3.0 graphic card, 3 Western Difgital 7200 rpm 1 Tb SATA Hard Drives
Jackson ( ) posted Sun, 06 October 2002 at 3:54 PM
Thanks for the tip. Did you reinstall Poser first?
MaxxArcher ( ) posted Sun, 06 October 2002 at 4:44 PM
DO NOT forget to make a backup copy of TPKX.VXD in your WindowsSystem directory prior to installing the P5-SR1 update.
The update overwrites this file and COULD cause both your P4 and P5 fail to startup and yam your PC. Should this be the case: simply restore the backuped TPKX.VXD, reboot your PC and both P4 and P5-SR1 should work fine.
You can find further info at Curious Labs`s twchnical support page.
Happy posing!
MaxxArcher
Crescent ( ) posted Sun, 06 October 2002 at 6:10 PM
I'd heard the same thing for W2k. I installed the pieces separately on my XP machine and it's running much better than unpatched. Personally, I figured it would be better to do them separately just in case I ever needed to restore some figures from the library without redoing the whole installation or patch job.
dcasey0284 ( ) posted Sun, 06 October 2002 at 7:53 PM
I downloaded the patches separately and It worked fine. I'm using Win2k. The sepatare download was mainly because I couldn't get the full version to dowload, so I dodn't try it. But I know the separate download worked for me. Someone here said it didn't matter which order you installed them, but I installed the 'apps' patch first and the 'figures' patch second. No problems so far.
EricofSD ( ) posted Sun, 06 October 2002 at 9:19 PM
I'm on win2k and don't have a tpks.vxd at all. I do, however, have a TPkd.sys version 3. Will make a backup of that before installing the two part patch.
