Sat, Feb 8, 11:32 PM CST
Subject: Help! Difference between render and screen shot
triceratops2001 ( ) posted Wed, 09 October 2002 at 2:14 PM · edited Sun, 02 February 2025 at 7:09 PM
I have such render, the skin is so grey
triceratops2001 ( ) posted Wed, 09 October 2002 at 2:16 PM
And this is what I got in the screen of pose room window
triceratops2001 ( ) posted Wed, 09 October 2002 at 2:18 PM
And the material is like this. Why is the color so different? Can someone tell what I need to do?
Jcleaver ( ) posted Wed, 09 October 2002 at 2:20 PM
I would check your lighting. The color of the lights as well as placement and strength.
triceratops2001 ( ) posted Wed, 09 October 2002 at 2:33 PM
The lighting will not show correctly in the document windows, only show in the render ? I don't have this happen in poser4, and got this in poser 5.. :(
quixote ( ) posted Wed, 09 October 2002 at 2:34 PM
and depth cuing
Un coup de dés jamais n'abolira le hazard
S Mallarmé
triceratops2001 ( ) posted Wed, 09 October 2002 at 2:48 PM
quixote, what should I do with the depth cuing ?
Jcleaver ( ) posted Wed, 09 October 2002 at 2:53 PM
The pose window can only give you an idea of what the lighting will look like. The reason it doesn't affect P4 is that P4 doesn't have the rendering engine that P5 has. If you were to use the P4 renderer within P5, you should get expected results.
quixote ( ) posted Wed, 09 October 2002 at 3:02 PM
I got that sort of thing when depth cueing was on. It looks alot like what you're going through. Try turning it off and see. Hope this helps.
S Mallarmé
triceratops2001 ( ) posted Thu, 10 October 2002 at 12:47 AM
Jcleaver, I have tried the P4 renderer, but still the same. I don't get this in P4, but I have this in P5. And quixote, I can't find the ' depth cueing ' . What is that and where I can trun it off?
quixote ( ) posted Thu, 10 October 2002 at 6:38 AM
In the pose window. Go to Window on the menu bar. Make sure "Document tools" is checked. At the right of the document window, you will find 3 nippleisf buttons. From the top it is the 4th button, before collisions and shadow. In your manual: page 138.
S Mallarmé
quixote ( ) posted Thu, 10 October 2002 at 6:43 AM
This be the one
S Mallarmé
