Mon, Dec 2, 12:04 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Nov 28 3:44 pm)
Carrara Free Stuff here.
Subject: Problem with duplicated obj
ziggie ( ) posted Sun, 27 October 2002 at 3:40 PM · edited Sun, 01 December 2024 at 11:53 PM
I have modelled a right hand (foot) sock in Carrara 1 for use in Poser 4. I export it into Poser, position and scale it and re-export into Carrara. I duplicate with symmetry to get the left sock and export into Poser. But no matter what I try I keep getting a right sock. Any help much appreciated.
"You don't have to be mad to use Poser... but it helps"
mateo_sancarlos ( ) posted Mon, 28 October 2002 at 2:31 PM
There's probably a more sophisticated way to do this, but I just export the duplicated object as dupe.obj, then import to Carrara again and now it's a new object with the desired symmetry.
ziggie ( ) posted Mon, 28 October 2002 at 5:00 PM
Agreed mateo... there's no problem there... the problem is when I open a duplicated object in Poser, it reverts to it's original (before duplication) form. :(
mateo_sancarlos ( ) posted Mon, 28 October 2002 at 9:41 PM
It should work right in Poser after you re-import it to a new file in Carrara, then re-export it as leftsock.obj.
ziggie ( ) posted Tue, 29 October 2002 at 3:57 AM
Thanx again mateo... yes I do the same... but still original obj when imported into Poser. I think the problem is that I am exporting the obj from Carrara with local coordinates switched on. If I save with local coordinates switched off, it works fine, but then I have to go through all the hassle of rescaling and repositioning the object in Poser. I was hoping the obj would import into Poser in its duplicated state, then I would just have to make a single (move it left) adjustment. It would be so much easier if there was a mirror or flip action in Poser, but as far as I am aware there isn't one.
bluetone ( ) posted Tue, 29 October 2002 at 7:49 AM
Try going into the modeling room in Carrara with the sock. Make a small edit, then undo it. If you then export, I think it will reset the coordinates to where they were in Carrara. Good luck!
ziggie ( ) posted Tue, 29 October 2002 at 5:57 PM
Thanx bluetone.... tried that, but no joy. It gets weirder by the minute..! I just tried this: Kept the original right sock in Carrara. Duplicated with symmetry so I had a right and left sock. Grouped both socks and exported in local coordinates into Poser . I end up with 2 socks... hurraay! 2 right socks that is... boooo! Both socks in the same position, one on top of the other.
