Carrara F.A.Q (Last Updated: 2024 Nov 28 3:44 pm)
Thanx again mateo... yes I do the same... but still original obj when imported into Poser. I think the problem is that I am exporting the obj from Carrara with local coordinates switched on. If I save with local coordinates switched off, it works fine, but then I have to go through all the hassle of rescaling and repositioning the object in Poser. I was hoping the obj would import into Poser in its duplicated state, then I would just have to make a single (move it left) adjustment. It would be so much easier if there was a mirror or flip action in Poser, but as far as I am aware there isn't one.
"You don't have to be mad to use Poser... but it helps"
Thanx bluetone.... tried that, but no joy. It gets weirder by the minute..! I just tried this: Kept the original right sock in Carrara. Duplicated with symmetry so I had a right and left sock. Grouped both socks and exported in local coordinates into Poser . I end up with 2 socks... hurraay! 2 right socks that is... boooo! Both socks in the same position, one on top of the other.
I have modelled a right hand (foot) sock in Carrara 1 for use in Poser 4. I export it into Poser, position and scale it and re-export into Carrara. I duplicate with symmetry to get the left sock and export into Poser. But no matter what I try I keep getting a right sock. Any help much appreciated.
