Wed, Nov 13, 6:50 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 12 11:30 pm)
Subject: Help ME!!!!!! plz... window problem.
itsik_m_18 ( ) posted Tue, 05 November 2002 at 7:09 AM ยท edited Wed, 13 November 2024 at 6:43 AM
look at the picture i put here and plz try 2 tell me what 2 do!! i cant move the window... plz... and 10x and bye 4 now...
mon1alpha ( ) posted Tue, 05 November 2002 at 7:20 AM
:) No worries go to Window Document size and then resize your windows size to....say 100x100 and you should be able to move it back to where you want it. Mon ps: if that doesn't work then try setting preferences to factory setting
Kelderek ( ) posted Tue, 05 November 2002 at 7:48 AM
After fixing this, it's a good idea to set a UI dot to help you restore it quicker next time.
itsik_m_18 ( ) posted Tue, 05 November 2002 at 8:17 AM
First of all BIG 10x the factory settings fixed it up.. and if im here so i will keep asking questions (and im sorry abot my english) ;) ok so my 2nd problem is a texture broblem... as u can c when i load the new texture it dosent fix 2 the model... and some times nothing happenz... my steps are ctrl + 9 rander > material and then i press on the load button in texture map and find the texture... but some tines nothing happens (when i try to load a lingerie texture) and some thimes it dosent fix ( as u can c) some 1 got any idea why? and again BIG BIG 10x
SamTherapy ( ) posted Tue, 05 November 2002 at 8:24 AM
You can only load a texture onto the model it's appropriate for. Example - Victoria textures don't work on the standard Poser female, and lingerie textures will only work on the lingerie model they were made for. There are a few exceptions, but they are very, very rare. What texture are you trying to apply to the model above?
PabloS ( ) posted Tue, 05 November 2002 at 4:42 PM
Actually Sam you CAN load any texture on any model that will take a texture. It may look odd, but you can do it. itsik_m_18If, I read your description right, try rendering. You usually won't see the texture until it's rendered unless you set the "document" window to display textures (which makes things move slow). I believe the setting is the last button. (Sorry, if I were at home I could ship you a screen shot.)
mon1alpha ( ) posted Wed, 06 November 2002 at 3:17 AM
Always ask questions here :) That's how I've learned things here, in fact I'm still learning after 2 years. There are lots of tutorials here as well bye for now Mon
