Tue, Feb 11, 2:53 AM CST
Subject: IK / export of bones
jn ( ) posted Fri, 07 April 2000 at 5:08 AM ยท edited Tue, 11 February 2025 at 2:47 AM
Hello to all ! Is there any way to get the bones out of Poser4 ? obj, dxf, 3ds... ? Thanx, -Juergen.
steveshanks ( ) posted Fri, 07 April 2000 at 5:16 AM
Poser doesn't use bones...its like a normal IK setup but with blending at the joints.....probably not the best explanation :o)......steve
LoboUK ( ) posted Fri, 07 April 2000 at 5:43 AM
Unless you're referring to exporting the skeleton (in which case OBJ is probably best) Steve's explaination is correct Paul
jn ( ) posted Fri, 07 April 2000 at 6:28 AM
First, thanx for the answers ! So, is there a possibility to export a model with the joints ? -Juergen.
LoboUK ( ) posted Fri, 07 April 2000 at 7:31 AM
If you are exporting to Bryce, you would have to pose the figure in Poser and export an OBJ file. Load this into Bryce and apply material and render. However, you would not be able to manipulate the figure - it would be locked into the pose you exported it in. If you are exporting to a high-end programme which supports character animation (something like 3D Studio MAX), you would have to import the figure from Poser so that you retained all of the seperate parts and then build the bones/IK chains for it in MAX (or whatever), then apply material before you started animating it. There is going to be a way to export an animated character from Poser to 3D Studio MAX - Konan is working on a MAX plugin which will do exactly this. The plugin is due May but will not allow you to actually manipulate the figure in MAX - this would have to be done in Poser Hope this clears things up for you Paul
jn ( ) posted Fri, 07 April 2000 at 7:38 AM
Hello again ! The first 2 points are clear. But I can not get the third: What will the plug-in do ? I already can export different poses now... -Juergen.
LoboUK ( ) posted Fri, 07 April 2000 at 8:10 AM
This plugin will export animated poses. You'll be able to set up an animated figure in Poser and export it to MAX where it will appear as an animated figure. Check out the MAX forum and run a search on Konan for examples of what he is planning Paul
jschoen ( ) posted Fri, 07 April 2000 at 11:52 AM
Now if they can can get this Plugin to work for carrara ;-)
pack ( ) posted Sun, 09 April 2000 at 12:04 AM
Cararra does not support bending joints or bones. I reco Boning you character in your second nonposer app, & importing the BVH from Poser. Seems like it accomplishes the same thing. I guess you were hoping to avoid having to set up a Poser/Zygote model Bones/IK chain was the point of your question?
jn ( ) posted Mon, 10 April 2000 at 10:22 AM
Yes, that was my hope Pack. :-( Does anybody know a tool to get these BVH-data into Maya ? -Juergen.
